Old 04-29-2010
RhythmDoctor's Avatar
RhythmDoctor will become famous soon enough
Cleaning out the fresh water system
My new (to me) C250 comes with a little 12 gallon fresh water system. Fortunately the galley sink is upgraded with an electric pump, so flushing is easy.
The system was left about 2/3 full over the winter (previous owner should be shot!). Fortunately there does not appear to be any damage from freezing. What's in the tank looks orangish, so maybe it has some non-toxic antifreeze. But maybe it's alive - I have no idea.
What do you guys suggest to disinfect the system? Does a Clorox solution work, and if so how concentrated? Something else? I don't want to have chlorine smell for years, but I do want to make sure to knock out any really bad stuff.
1998 Catalina 250WK "Take Five" (at Anchorage Marina, Essington, on the Delaware River)
1991 15' Trophy (Lake Wallenpaupack)
Old 04-29-2010
RD—
read this
Old 04-29-2010
sailak's Avatar
Omega 36
sailak is on a distinguished road
Thanks SD, will be refilling the water tanks on Saturday.
Dale
S/V Cirrus
Omega 36
Old 04-30-2010
SteveInMD is on a distinguished road
If you are having trouble getting rid of the chlorine taste after the above treatment fill the tanks with a vinegar solution at a rate of 1 quart vinegar to 5 gallons of water, pump this through the system until you can smell vinegar at each tap. Then leave this solution in the tank for several days, then drain and refill with water.
Old 04-30-2010
very good advice... vinegar is a good deodorizer.
convert from sea water to fresh water cooling.... john232 Gear & Maintenance 3 02-16-2004 03:44 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Refrigeration—Part II Selecting a System Tom Wood Gear and Maintenance Articles 0 05-19-2003 08:00 PM
cleaning a fresh water system gregreinhard Gear & Maintenance 1 11-12-2002 07:14 PM
