Old 05-03-2010
CalypsoP35's Avatar
CalypsoP35 is on a distinguished road
Polyurethane on toe rails?
Has anybody used polyurethane on their toe rails? A guy in the boat yard used it on his boat last year and loves it. He got the idea from longtime boaters that have been using it for years. One of my concerns was that it's not a good UV protector, but he claims it is.
Anybody have any thoughts?
Old 05-03-2010
Maine Sail's Avatar
If you're talking home center polyurethanes, definitely not a good choice for exterior finishing as it has either no or very minimal UV protection.
______
-Maine Sail / CS-36T
Old 05-03-2010
CalypsoP35's Avatar
After I posted, I did a little research and there appear to be new polyurethanes with UV protection that are for outdoor use.
Old 05-03-2010
deniseO30's Avatar
Lies about her age
Might be better on toenails!
Old 05-03-2010
RichH's Avatar
RichH will become famous soon enough
Urethane is good IF it has the proper UV blockers such as 'ferrous oxide' added. Many of the 'longest lasting & extremely expensive' boat wood finishes are urethane-acrylic or urethane-epoxide copolymers .... and the 'base coats' have the ferrous oxide UV blockers. The urethane for a watertight/vapor seal, the acrylic for the 'gloss'.
The 'problem' with straight polyurethane is that is a royal PITA to remove/repair, usually requiring deep sanding/scraping.
My previous (now abandoned) method including urethanes on brightwork was to use an oil based varnish loaded with UV inhibiters as the (thick) base coat, then urethane over top of that to 'seal' the coating from vapor (and sometimes 2 part clear urethane over all that. The 'modern' coating systems are faster and longer lasting.
Old 05-03-2010
wwilson's Avatar
Chesapeake Sailor
wwilson is on a distinguished road
Perfect - Very good d!
Wayne
s/v Virginia Dare
Old 05-03-2010
ROSA's Avatar
ROSA is on a distinguished road
Bristol Finish is a two part Poly with plenty of UV. We use it and get about 2 1/2 years service. We put it over three coats of West with 207 hardner. It is a very hard finish and tends to crack, at seams, yellow and lift.
Old 05-03-2010
Part of the solution
bljones has a spectacular aura about bljones has a spectacular aura about
Urethane doesn't like hard edges and corners.
Old 05-03-2010
Freesail99's Avatar
Freesail99 will become famous soon enough
Varnish can be repaired, Urethane can not.
S/V Scheherazade
Old 05-03-2010
tager's Avatar
tager is on a distinguished road
This whole thing has been solved for so long. Heat gun, scraper, 120 grit, 220 grit, varnish, brush, mineral spirits, respirator, and time time time.
Varnish is great at what it does. People search for a clear invincible wood finish that is easy to repair, cheap, and easy to apply with no maintenance.
It will never be found. Give up.
Deck Hand Rails alofns Gear & Maintenance 6 07-11-2010 12:05 PM
Rebedding aluminum toe rails cghubbell Gear & Maintenance 13 10-15-2009 12:36 PM
non teak rub rails and toe boards? jbarros Gear & Maintenance 3 11-04-2003 08:51 PM
