05-04-2010
Buy Don Casey's This Old Boat, 2nd Edition. It's a great starting point for you.
If you need to do fiberglass work, I'd recommend using epoxy rather than vinylester or polyester resin, since it will be a bit easier to use, and end up with a stronger repair. Get your epoxy from epoxyproducts.com rather than buying west or system3...since it is a very good epoxy from a company that knows boat building... and far less expensive.
If you need fiberglass, get it from fiberglasssite.com.
West systems has great reference material on their site, but IMHO, their epoxy is over-priced.
