05-04-2010
Originally Posted by brich001
I have a 1983 Alberg 37 with roller furler. This is my first furler, so I know nothing about these other than what I have read. Specifically, I don't know what model and vintage the furler is? The markings show it to manufactured by Harken (and perhaps sold by North Sails?).
1. How can I adjust the forestay tension? There is no visible turnbuckle to adjust. I have been told that some 'early' furlers contain no forestay turnbuckle under the furler. I need to move the forestay every year during haul-out at the bow to provide room the travel-lift to get close enough to lift the boat. Reconnecting the forestay would be MUCH easier if there is an adjustment turnbuckle under the furler.
2. How can I tell if this model is a furler-reefing system or just a furler?
brich
Most Harken furlers that I have seen are over a forestay turnbuckle so you likely can adjust forestay tension. You'll just have to figure out how to loosen and raise the drum to access the turnbuckle.
Harken is famous for great customer support so you could likely id you unit and get instructions by giving Harken a call.
As far as I know, all Harken furlers can be reefed. Basically, if you can unroll part of the sail and secure the drum so that no more sail can be deployed without you wanting it to, then you have a reefable unit.
PalmettoSailor (formerly midlifesailor)
s/v Palmetto Moon
1991 Catalina 36
