Are there any removable 4-stroke outboard brackets - Page 2 - SailNet Community
post #11 of 12 Old 06-06-2010
Here's what you're looking for:
Fulton Transom Adapter Fulton Boat Trailer Parts FTA6000134
Note that you have to buy the tilt bracket separately, which slides into this.
"The TA600 is designed for use with Fulton 1000, 1400 and 1700 series adjustable motor mounts. Just lift the motor and slide the mount bracket angles into the TA600. A conveniently placed lock pin hole allows the motor to be secured to the transom adapter. Includes all necessary stainless steel mounting hardware"
Rated for 20HP and 120# 2 stroke / 5hp 4 stroke. -> This lower 4 stroke limit is completely ridiculous, 4 strokes have LESS low end torque than 2 strokes thats why 2 strokes completely dominated dirtbike racing for 35 years. As long as you're within the weight limit I think you'll be fine, but that's up to you. I don't think a 77# 7.5 HP motor is exactly pushing the envelope here.
bb32 is offline
post #12 of 12 Old 06-06-2010
Rated for 20HP and 120# 2 stroke / 5hp 4 stroke. -> This lower 4 stroke limit is completely ridiculous, 4 strokes have LESS low end torque than 2 strokes thats why 2 strokes completely dominated dirtbike racing for 35 years. As long as you're within the weight limit I think you'll be fine, but that's up to you. I don't think a 74# 7.4 HP motor is exactly pushing the envelope here.
I have to completely agree here. My 80lb. Honda sat just fine on a 2-stroke motor mount for 35 years (that is all that was available back then) and when I took the mount off the boat to clean and lube it, there was very little damage (it WAS twisted a little). I now have a 57 lb. motor on it and works even better. IF you are running a big kicker, say 10 or 15hp and a heavy boat, then sure, but if you already have a mount, don't just toss it unless it's not working.
Best of luck
Kary
S/V Mariah
#49080
75R20 is offline
Diesel vs 4 stroke outboard??? bugged Gear & Maintenance 21 11-28-2010 07:15 PM
2 stroke vrs 4 stroke outboards dsbentley Gear & Maintenance 11 07-11-2006 12:27 AM
The Great Stroke Debate Tom Wood Cruising Articles 0 03-31-2003 08:00 PM
Outboard Motor Brackets Sue & Larry Gear and Maintenance Articles 0 09-04-2002 09:00 PM
Honda 4 stroke outboard mikehoyt Gear & Maintenance 4 05-24-2002 06:08 AM
