Old 05-05-2010
Yankee22 is on a distinguished road
Sealing new windows
Could I use butyl tape to seal my through bolted windows? I like the idea of being able to take them out again if one ever breaks. (They are glass)
If not, what kind of caulk, silicone, adhesive should I use?
Thanks in advance everyone
Ryan
Old 05-05-2010
Cruisingdad's Avatar
Best Looking Moderator
Scs 2000.
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Old 05-05-2010
SailingWebGuy's Avatar
SailingWebGuy is on a distinguished road
I just bought a window rebuild kit from CatalinaDirect for my Catalina 30. It came with Dow Corning 795 for between the aluminum frame and the glass. Also came with 3M's 4200 for between the aluminum frame and the deck.
I'm not sure how either will work yet...still have to clean up the windows, seal them, and get them installed.
Old 05-05-2010
sawingknots's Avatar
sawingknots is on a distinguished road
i think the butyl tape should work fine and if it ever leaks you can always do different,just don't use 5200 !!!
Old 05-06-2010
If they are through-bolted...then you should be fine with butyl tape.
Advise on dodger windows please? SanDiegoChip Gear & Maintenance 15 04-14-2010 05:53 PM
Seating New Windows seb5thman Gear & Maintenance 39 04-09-2010 09:35 PM
Replacing Windows seb5thman Gear & Maintenance 5 02-12-2010 07:02 AM
Sealing Windows nlowin Gear & Maintenance 8 03-30-2004 12:13 AM
Leakey windows ALF Gear & Maintenance 3 04-07-2001 10:01 PM
