Old 05-05-2010
davidpm's Avatar
davidpm is on a distinguished road
Outboard 25 years old
Is this normal oil sheen for a two stroke?
It was running but had problems with idle.
It stopped oiling the water eventually.
Old 05-05-2010
xsboats's Avatar
xsboats is on a distinguished road
Sounds like the float is stuck in the carb. Poor idling could be due to flooding.The sheen looks like unburned fuel exiting from the exaust.
Old 05-06-2010
Leither's Avatar
Retired and happy
Leither is on a distinguished road
I agree with xsboats - definitely a flooding problem. Could certainly be a sticky float valve or simply too much choke on starting?? Anyway, as long as it doesn't keep doing it, you should be OK!
Stuart
Leith (rhymes with teeth) is the port of the City of Edinburgh in Scotland. A Leither is someone who comes from that area.
I must go down to the sea again, to the lonely sea and the sky - I left my shoes and socks there, I wonder if they're dry?
Old 05-06-2010
tommays's Avatar
Well
I would think it could use a fuel pump kit or replace and a carb kit
BUT it is pretty normal even my last of the line 2005 2stroke will turn a 5 gallon bucket pretty nasty in about 3 minutes you just dont see it as much when your on the water
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 05-06-2010
davidpm's Avatar
The motor just came back from the shop and was supposed to be tuned and had some parts replaced.
Maybe we just over choked it.
Old 05-06-2010
chucklesR's Avatar
Gemini 105Mc Hull 987
chucklesR is a jewel in the rough chucklesR is a jewel in the rough chucklesR is a jewel in the rough
Could be just oil on the outside washing off even. If it doesn't continue it's not a big deal.
"The past is the cause of the present and the present will be the cause of the future" Abraham Lincoln
Old 05-06-2010
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
Are your certain the fuel/oil mixture you are using is correct? We had a 1963 Evenrude Angler for 40 years and too much oil in the fuel resulted in an oil slick such as you describe.
FWIW...
Old 05-06-2010
Stiche's Avatar
Custom Member
Stiche is on a distinguished road
Looks like you need to have the low speed circuit and the float valve checked in the carb. I think we're building a consensus here
My guess is you have deposits in the carb that are gumming up the valve. As the engine warms up, the valve begins to move more freely, and...you stop pushing out excess fuel out your exhaust. So...yes, it's normal, but you should send it in for a tune-up.
Stiche
"Sattar" Cal 25, #256
Old 05-06-2010
davidpm's Avatar
The mechanic came back today and surprise, surprise it was supposed to be tuned up but he didn't recognize the engine so it must have been missed.
He adjusted something on the carb and it runs a lot better now.
Will get full tune up shortly.
Thanks all.
hard to buy/insure boats older than 20 years? rmeador Boat Buyers & Sellers Forum 30 07-27-2010 06:03 PM
help: Comprehensive outboard spare part list MATHURIN Gear & Maintenance 2 12-11-2009 09:25 AM
From the Origin of Time to the Y2K Jim Sexton Seamanship Articles 0 10-14-1999 08:00 PM
