Old 05-06-2010
davidpm's Avatar
davidpm is on a distinguished road
Outboard 25 years old
Is this normal for a two stroke 8 hp motor?
It stopped after a while.
Old 05-07-2010
faisond is on a distinguished road
Check gear case plugs
Suggest checking gear case plugs for tightness or leakage if you haven't already. The screw-in plugs are likely to have some gasket or washer behind them that may have deteriorated allowing gear case oil to leak out. Gear oil should be changed periodically anyway. Of course, any fuel leak dripping overboard can cause a sheen like your photo. In my experience, a suprisingly small amount of oil/fuel will produce a sheen of a size that seems out of proportion to the amount of leakage.
Old 05-10-2010
mlsalwa is on a distinguished road
seal
had same problem with my 1987 Nissan. Check the seal behind the prop. The seal keeps the gear oil in the lower unit.
hard to buy/insure boats older than 20 years? rmeador Boat Buyers & Sellers Forum 30 07-27-2010 06:03 PM
help: Comprehensive outboard spare part list MATHURIN Gear & Maintenance 2 12-11-2009 09:25 AM
From the Origin of Time to the Y2K Jim Sexton Seamanship Articles 0 10-14-1999 08:00 PM
