Looking for vang attachment hardware - SailNet Community
post #1 of 13 Old 05-06-2010 Thread Starter
Broad Reachin'
kwaltersmi's Avatar
My boom has a square-ish metal plate riveted to the bottom of the boom, matching the boom's curvature. In the middle of the plate is a hole with a slot on one end. That's the best I can describe it without a picture.
Does anyone know where I can find the "male" fitting that would attach to my vang so it can connect to the plate on the boom? Anyone know what I'm talking about? I'm assuming the part I need would look something like an enlarged nail head so it could fit into the hole and then slid back to lock it in place.
Catalina 34
kwaltersmi is offline
post #2 of 13 Old 05-06-2010
I think the vang may have had a short cable pendant with a swaged ball end fitting. A rigging shop could make something like that up for you.
Gary H. Lucas
GaryHLucas is offline
post #3 of 13 Old 05-06-2010 Thread Starter
Broad Reachin'
kwaltersmi's Avatar
Good call Gary...you may be right!
I may just add a boom bail, though I'm hesitant to drill/screw into the boom.
Catalina 34
post #4 of 13 Old 05-07-2010
One of our former boats had this same fitting - it was a keyhole slot for the vang, the tackle for which was connected via a "nail-head" type of stud that slotted into the fitting.
This was on a boat originally fitted with roller boom reefing... I believe it was to allow the vang to be used for a full main, but quickly removable to facilitate rolling the boom for a reef (but ironically leaving you 'vangless' when you perhaps needed it most)
Faster is offline
post #5 of 13 Old 05-18-2010 Thread Starter
Broad Reachin'
kwaltersmi's Avatar
After contacting Ronstan and Harken, it looks like the part I may need is called a "vang key". But the funny thing is that they seem to be made almost exclusively for Lasers, so it may not be stout enough for my application. I'll post a picture later today...
Catalina 34
post #6 of 13 Old 05-18-2010
Depending on the size of your boat/boom, the key slot that you describe is made for a rigging fitting that is usually used on the upper end of a mast,on a shroud/stay. Check with a rigger/sailboat supply for a "T slot fitting " or "T ball" used in a mast. WM lists 3 different styles and several sizes.
Best of luck
Kary
S/V Mariah
#49080
75R20 is offline
post #7 of 13 Old 05-18-2010 Thread Starter
Broad Reachin'
kwaltersmi's Avatar
Thanks for the tip 75R20!
FYI - Here's a picture of what I'm referring to:
Catalina 34
post #8 of 13 Old 05-18-2010
Exactly what we had on a former boat.. the top block for the vang had that 'nail head' fitting that slotted into that keyhole.. as long as the vang had some tension it stayed put.
Is this an originally roller-reefing boom set up?
Faster is offline
post #9 of 13 Old 05-18-2010
YUP !
Kary
S/V Mariah
#49080
75R20 is offline
post #10 of 13 Old 05-18-2010 Thread Starter
Broad Reachin'
kwaltersmi's Avatar
It was never a roller-reefing boom to my knowledge. Nor is there any evidence of such a set-up, except the key fitting (subject of this thread).
It looks like the t ball parts that West carries are all swage fittings. I'm really hoping to find a piece that looks like an eye-bolt with the t ball fitting (nail head) instead of the threads, if such a thing exists. Then I could simple fit it to the slot and attach the snap shackle from my vang.
Catalina 34
Deck Hardware Don Casey Gear and Maintenance Articles 0 09-27-2002 08:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 08:00 PM
