Old 05-07-2010
Pub911 is on a distinguished road
Exhaust system replacement using mostly Trident?
My 1972 NorthStar (Hughes) 38 has a Universal M4-30, 25hp diesel engine that's fitted with a raw-water-fed water-jacketed exhaust tube that's about 2 1/2 feet long - an inner pipe of exhaust gas surrounded by a sealed tube where raw water flows.
The flanged end of this unit is fastened to a dry, glass-matt-wrapped black-iron exhaust pipe/system that exits the boat about 15 feet away - a home-depot parts, custom pipe-fitted frankenstein of a set-up installed by the PO.
The raw water used in the jacket above rejoins the exhaust pipe about 2 feet from the end of the black-iron exhaust pipe and flushes out through a seacock.
The glass-wrapped black iron fails about every 10 years. Cost of a custom fab'd SS exhaust is staggering. Can I use Trident exhaust-rated hose on this application or is it too hot (even though exhaust is cooled via the 2-foot double-pipe back at the engine)?
Any other ideas on how to solve this perrenial failure item?
Old 05-08-2010
tommays's Avatar
Its a BIT hard to understand what you have
On older boats like my A4 there is a hot section warped in insulation and then its pretty much like any other boat in that i don't know of any gas or diesel inboard that does not go to the correct rubber right after were the water is injected to cool the exhaust stream
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 05-08-2010
JimsCAL's Avatar
JimsCAL is on a distinguished road
The installation on my old Universal 5411 was a black iron pipe loop to a plastic waterlift muffler then exhaust hose to the outlet. You can't use hose before the water injection at the back end of the loop. Too hot.
Old 05-09-2010
So I guess it really comes down to: how hot does the existing black-iron get?
And I guess I can answer this by putting an infrared reader on it. So assuming I get a range comfortably within the Trident high-point (which is around 400F).
Can I trust that this reading is not going to be exceeded?
Will an overheating situation melt the tube?
Does anyone know how much fluxuation there is likely to be on the exhaust temperatures if the engine were to overheat?
My point in asking is that I wouldn't want to set myself up with a solution that was too sensitive to withstand typical running variation - which may on rare occaission, involve a temporary overheat if say, a bet broke and went unnoticed until the temp alarm went off.
Thank you.
Old 05-10-2010
JimsCAL's Avatar
Engine exhaust temp will be 400F+ at load.
Exhaust System Repair skhorleb Atomic 4 7 12-06-2006 12:03 AM
Catalina 30 Exhaust Hose Replacement langweer2 Gear & Maintenance 0 09-22-2006 10:28 PM
Refrigeration—Part II Selecting a System Tom Wood Gear and Maintenance Articles 0 05-19-2003 08:00 PM
Diesel Exhaust Systems Sue & Larry Gear and Maintenance Articles 0 11-07-2001 07:00 PM
Spartite 2000 mast wedge replacement system - need info Capt.CarroleWard Gear & Maintenance 2 05-30-2001 06:01 PM
