05-08-2010
Part of the solution
1. Farymann single cylinder diesels only need about a gallon to a 1.5 gallons per minute of coolant flow, so if your garden hose was pumping any faster than that, you weren't doing your engine any favours.
2. Unless you have two water pumps, the water that cools the head is the water that cools the block. On Farymann one-lungers, like most low hp single cylinder diesels, the coolant system is pretty rudimentary as far as the block and head are concerned. Best case scenario, you have a worn pump shaft or seal. Worse case scenario, you have a bad head gasket. Worst case scenario, a cracked block. I'd pull the pump first and give it a look-see.
Is it hard to start? If not, then a head gasket is less likely than a pump issue.
3. Caleb might be onto something, vis a vis oil changes. You might want to do another flush and fill of the crankcase, or two, to eliminate the possibility of residual condensation from winter layup. A couple of quarts of oil is cheaper than a single hour of mechanic's time.
