05-11-2010
More Info - Not the Pump
OK, my injector pump is not bad. The problem was a misunderstanding of how the regulator works. Unlike most machines, the regulator is wide open when fully shut. I had it backed off. Closing the regulator develops pressure in the pump and to the injector.
However, after bleeding at the injector the motor still won't start. I put a touch of ether in it and it does ignite and run for a couple of rotations. (I only used a very little amount!) My next step it replace both filters and re-bleed. If it still won't start, I'll take a look at the injector.
BTW, had I needed a new injector pump, Gulf Coast Composit, www.gulfcoastcompostit.com, has the pump for $249 or you can get the "plunger and barrel", the main wear component of the pump, for $63.
Homer Shannon
