  #11 (permalink)
Old 05-09-2010
DrB DrB is offline
DrB is on a distinguished road
Softscrub
Soft Scrub® - Guides
Safe for Fiberglass.
DrB
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
  #12 (permalink)
Old 05-09-2010
SVlagniappe's Avatar
SVlagniappe is on a distinguished road
Another product to consider is Davis FSR.
Marine and Boating Products by Davis
I've used it to remove the ICW mustache, and stains from the under the A/C discharge as well as black streaks. This stuff is magic.
Steve
SV lagniappe
Beneteau 423 #310
  #13 (permalink)
Old 05-09-2010
HatterasJack's Avatar
Live to Sail
HatterasJack is on a distinguished road
Guys,
Have tried everything to remove black streakes from both camper and Boat. Even removed finnish on camper to the bare metal in one spot!! Cleaner was too harsh. One day at a camp ground an old lady was ambiling around her motor home with a spray bottle of WINDEX!!!! I thought can't be that simple!!! I went over to inspect her spray application and remopval with a paper towel of ALL black streaks with no effort at all! 10 min. she was done and the motor home looked new!! She said all the young people try that fancy stuff but this works the best. I was floored!!!! She also said that if you have bad black streakes on any fiberglas parts that Fantastic works, full strenth then wipe off and rinse with plain water. I tried it. Both work GREAT!!!
  #14 (permalink)
Old 05-10-2010
MMR's Avatar
MMR MMR is offline
MMR is on a distinguished road
Send a message via AIM to MMR
We've also had success using Simple Green to remove the black streaks. Its our onboard cleaner of choice now, for nearly everything.
s/v Patience Two
Gemini 105MC
  #15 (permalink)
Old 05-10-2010
josrulz's Avatar
Unpaid Intern
josrulz is on a distinguished road
Thanks MMR--which version do you use? One of the household? Marine? I think the main difference is concentrations, but just wondering...
Thanks!
-J
1984 Sabre 34 Mk I
  #16 (permalink)
Old 05-10-2010
eryka is on a distinguished road
Our hull is painted so maybe our needs are different. I'm with Dr B. The Shaklee product I mentioned is just the organic version of softscrub. We used it every day when we had the kitchen/bath remodel company - and because we were exposed so much, we were finickier about using organic products. Now with just occaisional exposure, I'd probably use Softscrub - easier to find.
Gotta try Windex next tho!
  #17 (permalink)
Old 05-10-2010
14432's Avatar
14432 is on a distinguished road
Thanks!
-J
`I've used both versions and see no diffference.
  #18 (permalink)
Old 05-10-2010
DrB DrB is offline
Softscrub again...
If you have a painted hull, I would test the whether or not the SC scratches the finish. I would be very careful with it on Awlgrip. SC has calcium carbonate as the "abrasive" which is "soft" as far as hardness, but Awlgrip is very sensitive to abrasion.
On gelcoat, there is no issue.
DrB
  #19 (permalink)
Old 05-11-2010
josrulz's Avatar
Unpaid Intern
Thanks everyone for the suggestions. We'll definitely give some of them a try.
Cheers!
-J
1984 Sabre 34 Mk I
Tips For Compound, Polish & Wax Maine Sail Gear & Maintenance 172 1 Week Ago 05:50 PM
The Salt's Corner Table smackdaddy General Discussion (sailing related) 125 10-02-2011 06:10 PM
Spring Hull Cleaning Tom Wood Gear and Maintenance Articles 0 04-05-2004 08:00 PM
Hull Speed Demystified Steve Colgate Learning to Sail Articles 0 06-10-2000 08:00 PM
Hull Speed Demystified Steve Colgate Buying a Boat Articles 0 06-10-2000 08:00 PM
