Old 05-10-2010
Brucerobs2 is on a distinguished road
Broken bow Chock Bolt
So this weekends high winds,a very low tide, and probably too tight a dock line combined to break off one of the bolts that holds down a bow line chock near my bow cleat on my 80 Hunter 27. The bolt broke off about 3/4 of an inch down, leaving the remaining length of the bolt inside. Other than some surface damage where to bolt broke free, there doesn't appear to be any major additional damage, although I need to investigate further. Looks to be drilled into solid glass but possibly a glass/wood combo on the bow.
My initial thought about repairing is to extract the remaining bolt length, filling with epoxy, and then re-drilling and mounting (potting?). Assuming I can successfully extract the bolt (and the damage is minimal) which I have never done before, am I missing anything? Any tricks to drilling/extracting a stainless bolt? Seems straightforward enough. Any pitfalls I should be wary of? Can't be the first time this one has happened. Thanks.
Old 05-10-2010
chucklesR's Avatar
Gemini 105Mc Hull 987
chucklesR is a jewel in the rough chucklesR is a jewel in the rough chucklesR is a jewel in the rough
Bruce,
That was some major wind this weekend wasn't it. Sorry for the damage.
The bolt also has a nut; you are going to have to look inside at the lining and work out how to get the lining out and get the nut off from underneath.
Part of that will show you if you can remove the remainder of the bolt from there, or if you'll have to drill it out.
They make a lot of good products for backing out bolts and screws that have lost their heads - this one might be tough as it's bedded in epoxy. If that is the case, after you get the nut off drilling it out and then refilling with epoxy is a solution.
It might not be strong enough though - you may have to cut back some more, add some filler etc..
Try the hunterowners forum for other owners and they can give you some 'been there, done that' advice.
"The past is the cause of the present and the present will be the cause of the future" Abraham Lincoln
Old 05-10-2010
SVCarolena's Avatar
Pearson 303
SVCarolena is on a distinguished road
Your plan sounds fine. I saw several boats at our marina this weekend hanging from the bow lines. Are you able to reach the underside of the deck where the chocks are mounted? If so, you may want to think about going with a thru-bolt and backing plate after you fill and re-drill the holes.
Encapsulated or Bolt On Keel? aasault Boat Review and Purchase Forum 34 06-19-2011 09:20 AM
Keel Bolt Repairs Don Casey Gear and Maintenance Articles 0 11-10-2003 07:00 PM
Keel Bolt Concerns Don Casey Gear and Maintenance Articles 0 10-12-2003 08:00 PM
Breakdown in Paradise Mark Matthews Gear and Maintenance Articles 0 04-29-2002 08:00 PM
The Basics of Doing the Bow Rich Bowen Racing Articles 0 03-20-2002 07:00 PM
