05-10-2010
Wet rudder maintenance
When I bought my current boat she was out of the water for quite some time and the rudder was dry but with expansive voids inside the foam. I drilled number of holes in the shell and filled the voids with Sikkaflex. I made grove around the rudder stock and filled it with Sikkaflex too. The rudder was covered with several layers of high build epoxy and antifouled.
Next time the boat was out of the water the rudder was wet. I drilled a hole at the bottom of the rudder and drained the water. Now the rudder is dry again.
Stainless still is prone to corrosion in wet anoxic conditions, which means the rudder frame inside is in danger of desintegration. On the other hand, it is very difficult to seal the rudder since the air inside expands and contracts with water temperature and the rudder shell works as a pump until it sucks enough water to equalize the presser inside and outside the rudder.
If it is true, maybe it is better not to seal the shell and make arrangements for better rudder ventilation, so that more oxygen will enter the shell with water and corrosion will be less active?
