Old 05-11-2010
rcourcier is on a distinguished road
mercury 3.3 trouble
I have a mercury 3.3 that will not run when in gear. I have some outboard knowledge, I've rebuilt the carb got the engine running well. It was running in gear well until today when I left the harbor and put the engine in gear and it would die when I gave it juice. I recently had the motor off the lower end to lube the gear shifter and replaced the gear oil and now this problem has ocurred. Any help!
Old 05-11-2010
Has it 'run well' at all since you serviced the lower unit? Will it continue to run if you choke it - even partially?
Will it "idle' in gear or does it stall immediately upon engaging the fwd gear? If it idles OK I'd guess the gearing is OK, and unfortunately this still sounds like a clogged jet situation despite having rebuilt the carb.
1984 Fast/Nicholson 345
Old 05-12-2010
yep
I does run at idle in gear and will continue to run in gear if I work the choke. maybe back to the carb huh.
Old 05-12-2010
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
I agree with Faster, I had to clean my carb twice last weekend, it doesn't take but a tiny tiny speck to foul a jet or two
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
Old 05-12-2010
carb screw
I siphoned the gas out, sprayed the carb, put new gas in with marvels and took the engine out to the boat and the same deal. not throttling up in gear. I turned the carb screw all the way in and slowly backed it out until the engine was running smoothly and now it's golden. took a couple laps around the harbor. Thanks
Old 05-12-2010
Well, you're lucky, I had to row back
1978 Tayana 37
How to trouble shoot yacht problems with a laser temp gauge DIY yachtwork General Discussion (sailing related) 0 01-01-2010 12:07 AM
Mercury 2.5 Hp problems Goodwood Gear & Maintenance 2 09-14-2009 02:47 AM
Experienced sailor, 47, missing at sea - San Jose Mercury News NewsReader News Feeds 0 11-13-2006 03:15 PM
Mercury 25 4-stroke dlschilke24 Gear & Maintenance 0 05-25-2004 06:31 AM
Merc 3.3 Dink Motor primowon Gear & Maintenance 1 07-10-2003 11:10 PM
