05-12-2010
I installed a Diaphragm pump (as opposed to the usual Centrifugal Bilge pump) for my maintenance pump. Unlike Centrifugal pumps, Diagram pumps can be run dry without damage (which is why Centrifugal switches don't kick on until the water is 2.5" high), and have check valves built in, so the water doesn't flow back into the bilge. However, they don't pump the volume required for an emergency, so I have a regular bilge pump with a float switch as well. I used a electric switch which senses the water level for the maintenance pump, attached to a ON/OFF switch. This setup keeps the water level in my bilge to about half an inch on Automatic. Unfortunately, my old diesel apparently leaks a small about of oil into the bilge. The oil coats the electronic switch thereby connecting the two sensors. So, unless I wipe off the sensors, it is no longer shuts the pump off automatically. So I use it in manual mode once a week and it still keeps the water level much lower than the float switch would. If you don't have and old diesel that sits midships directly above the bilge, this shouldn't be an issue. I posted a thread here when I installed it if you want to search for it.
