Old 05-12-2010
QuickMick's Avatar
QuickMick is on a distinguished road
sanding fiberglass repair
Ive been reparing some fiberglass (laying new mats), and am wondering if anyone has suggestions on the best type of sandpaper and grit to use to finish it. My buddy has some stick and sand glasiers disks but they are very abrasive.
thanks gang
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 05-12-2010
deniseO30's Avatar
Lies about her age
Mick if you using epoxy you will need the hardest grits you can find.. that stuff is tough!
Old 05-12-2010
tommays's Avatar
Norton
grit depends on the tool and what stage your at
I have used a BUNCH of disks Bosch, Festool, ect and found Norton to be the best so far
The Festool may have better but the stuff my DIS offered had issues with the backing failing at the outer edges were the Norton backing would hold up until the paper was really worn out
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 05-12-2010
Part of the solution
bljones has a spectacular aura about bljones has a spectacular aura about
Ditto on Norton 3X sandpaper. Start at 80 grit to hit the high spots and rapidly knock down the finish, then go to 220 grit, 320 grit, and so on, depending upon finish.
But first, make sure you have enough epoxy laid on to sand out! make sure that the weave is fully saturated, no low spots, and is smooth to the touch. There is nothing worse than sanding through the glass simply because you stopped one coat short when you wetted out the cloth.
Old 05-12-2010
80 grit is about the most aggressive you want to use typically. I'd agree with Tommays and bljones about Norton being a bit betterr to use. Don't forget to rinse off the amine blush before starting sanding.
The legacy of Philip Rhodes GoodOldBoat Buying a Boat Articles 24 03-09-2012 04:06 PM
High Tech vs traditional-Comments? Pangaea General Discussion (sailing related) 38 08-07-2007 01:07 AM
Repairing Gelcoat Cracks and Chips Don Casey Gear and Maintenance Articles 0 11-06-2002 07:00 PM
First Fiberglass Repair SailNet Gear and Maintenance Articles 0 09-01-2001 08:00 PM
