05-12-2010
I'd second using tubular webbing. IIRC, the second most common mode of failure for mooring, anchor and dock lines is internal friction/melting—the first is chafe.
If you use rubber or plastic hose, fire hose, or leather, the chafe protection can prevent water from getting to the line, allow heat to build up by trapping it. Using a woven chafe protector, like tubular webbing, will often allow water to get to the line, lubricating and cooling it.
