Old 05-12-2010
moonie5961's Avatar
1974 Contest 31'
moonie5961 is on a distinguished road
paint compatibility
removed
Old 05-13-2010
ASA and PSIA Instructor
Originally Posted by moonie5961 View Post
Does anyone have any preference on fairing mix? I think I'm going to use watertite, as it's recommended by interlux and has pretty good reviews on Jamestown distributors.
No on the Watertite, Watertite is a filler, not a fairing compound, it is very hard to sand, not what you want for fairing. If you have holes into the fg, then fill them with Watertite, otherwise I'd use a mixture of West epoxy w/microballons, but you can discuss your situation with Interlux directly, they will give you the best advice you could get.
Contact Us
By Phone:
We are happy to answer any product questions you may have and to give technical support on the application of our products. The Interlux technical service helpline 800-468-7589 is open Monday through Friday to assist you.
Old 05-13-2010
CharlieCobra's Avatar
On the hard
CharlieCobra has a spectacular aura about CharlieCobra has a spectacular aura about
One way to test old paint is to take MEK and work an area to see if it softens. Most one part paints can't stand up to MEK while the two parts can.
Baggett and Sons Marine Restoration
The Landing at Colony Wharf
Bellingham, WA.
Old 05-13-2010
Thanks for the tip!
Have you used it personally? I will defer to your experience, but this was copy and pasted from the interlux description.
Interprotect Watertite YAV135 is an excellent fairing compound due to its unique two-phase cure, which gives a long easy-to-sand window. Interprotect Watertite YAV135 can be applied to a thickness of 3/4" without sagging and its superior spreadability makes it an ideal glazing compound for filling small nicks and scratches.
I have no idea, I'll give them a call. thanks for the input!
At $50+ a can, I used far more of this stuff than I want to remember...
If you go to
yachtpaint.com - the official site of International and Interlux paints
Here's their comments on several products:
Interfill Epoxy Filler
A two part epoxy putty designed for fairing and smoothing a surface when a fine finish is required.
Watertite
Interprotect Watertite YAV135 is especially recommended for use to fill gelcoat blisters below the waterline. It is recommended for use with the Interprotect Epoxy Barrier System or VC Tar2.
The key words above that should be retained in any reference for Watertite is "below the waterline", otherwise forget it and its expense. Whatever the "sanding window" may be is not clear, and doesn't matter if you can't pick and chose when you can do your follow-on work.
Bottom paint prep, chipped paint josrulz Gear & Maintenance 16 02-14-2010 08:24 PM
The Bottom Paint Blues Don Casey Gear and Maintenance Articles 0 06-22-2003 08:00 PM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 07:00 PM
Bottom Paint Compatibility Dan Dickison Gear and Maintenance Articles 0 01-24-2001 07:00 PM
Paint the Bottom Yourself Tom Wood Gear and Maintenance Articles 0 03-09-1999 07:00 PM
