05-13-2010
I would flood the outside of the window to see if it is the outside bedding is leaking, if it is, then I would work on removing the window very slowly; I used the wide end of a small catspaw and very slowly broke the seal around the port ( working it all the way around )
If the outside isn't leaking, it could be just condensation getting behind the inside trim over time ( looks like you might have slick walls )
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
