Headliner replacement options? - Page 2 - SailNet Community
post #11 of 15 Old 04-21-2011
I am in the process of replacing my headliner and am using FRP Fiberglass reinforced panels. It is easy to work with.
John Ferrell
B SEA NU
Gemini 3000
johnferrell is offline
post #12 of 15 Old 04-21-2011
Old Fart
DwayneSpeer's Avatar
Originally Posted by jklewissf View Post
My boat has the overhead of thin plywood covered with white formica. The joints are covered with thin teak battens held in place by screws with finish washers. It looks good and gives very good access.
I've seen this done on at least one other boat and it looked quite good.
Hey, can one of you guys pass me a crab?
DwayneSpeer is offline
post #13 of 15 Old 04-21-2011
mitiempo's Avatar
Here's a link to how it is done with pics. It is about halfway down the page.
Atom Voyages | Nicholson 31 Refit
Brian
mitiempo is offline
post #14 of 15 Old 04-23-2011
brian,
thanks for the reply. i think that for now i will leave the current headliner in place and support it with some teak bows that follow the curve of the cabin top inside. that should hold up this sagging liner . the liner itself is not torn but one zipper is broken. i am considering next year taking out the liner and putting in a slightly "dropped ceiling" from 1""stringers" where any slat could be easily removed for servicing wires or fastenings. you're right though, it needs to be covered in some way.
watergirl
jmoesswilde is offline
post #15 of 15 Old 04-23-2011
Thanks Courtney.
Originally Posted by T37Chef View Post
FWIW...I replaced the headliner in our Tartan with a Masonite type product from Home Depot. Some would say not the best product to use but I figured it was pretty much the same as what was in there and that lasted for almost 30 years. If it gets wet it will have to be replaced, but then I don't have any leaks in the deck. It is covered with a glossy white finish on one side and easy to work with. I used the old ones as a template and I also add some insulation when we replaced it, boat seems a little more cozy now and has a new headliner
I did pretty much the same thing, but used the white beadboard paneling made from pretty much the same masonite material.
hunter Legend 37 Semper Paratus
Formerly - Tartan 34C Yawl
T34C is offline
Teak Deck Replacement - Flexiteek rbaker6966 Gear & Maintenance 8 04-16-2008 11:53 PM
Electrical Power Recharging Options for Extended Cruise Stormer Cruising & Liveaboard Forum 9 10-10-2006 02:07 PM
Shaft replacement or ''the shaft''? foxglove Gear & Maintenance 4 08-18-2006 11:16 PM
HF Email options jfkdgo Gear & Maintenance 1 01-09-2004 08:56 PM
Freight, Options and Commissioning megit Boat Review and Purchase Forum 2 12-19-2001 03:13 PM
