Old 05-13-2010
NWS NWS is offline
NWS is on a distinguished road
What type of paint to use?
I'm planning on painting the deck and hull of my 22' Pearson, and wondering what brand of paint to use. I know I want to use a 2 part poly, so it's now a question of Interlux, or Awlgrip. Is the Interlux product just a good and will hold up over time?
Old 05-13-2010
pdqaltair's Avatar
pdqaltair is on a distinguished road
Both are Akzo-Noble. Awlgrip is for spraying, Interlux is for brushing. No, it is not quite that simple, but close. You probably want Interlux Perfection.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
Old 05-13-2010
OldColumbia's Avatar
Hull Number 33
OldColumbia is on a distinguished road
You might want to keep it simple with one step poly ( such as West Marine top side enamel) to roll and tip, then Interlux non skid deck paint for the topsides. Remember it's a Pearson 22, not a Hinkley 50. Other than your personal delight, it's not going to increase in value and more maintenance is less sailing.
Old 05-13-2010
mitiempo's Avatar
The one part poly (West, Brightside) will not wear like Perfection and will need re-doing years sooner. The prep is about the same as far as time goes (90% of the job) and the finish will be tougher with the 2 part Perfection. Costs a bit more. It won't increase the value but will mean more years between paint jobs. If you use Perfection you can overcoat with 1 part down the road but 2 part can't be used over 1 part.
OldColumbia
Interlux Deckcote is great for the non skid areas of the deck but I'd want the topsides (hull) shiny.
Brian
Type of Paint for Haul-out geetcher Catalina 0 03-19-2010 10:18 AM
Determining type of paint used on Deck dm567 Gear & Maintenance 2 01-08-2007 09:12 PM
The Bottom Paint Blues Don Casey Gear and Maintenance Articles 0 06-22-2003 08:00 PM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 07:00 PM
Paint the Bottom Yourself Tom Wood Gear and Maintenance Articles 0 03-09-1999 07:00 PM
