Good enough - Page 7 - SailNet Community
post #61 of 66 Old 05-19-2010
bljones's Avatar
RD, why do you confuse honesty with rudeness?
You have had an issue with my posts in the past. If you don't like what I write, ignore it. If you don't want to ignore it, then pull up your underroos and HTFU, buttercup.
bljones is offline
post #62 of 66 Old 05-19-2010
On the hard
CharlieCobra's Avatar
I like the term HTFU...., always have....
If'n ya don't recognize the term, watch this: YouTube - Chopper - Harden Up Australia!
Baggett and Sons Marine Restoration
The Landing at Colony Wharf
Bellingham, WA.
CharlieCobra is offline
post #63 of 66 Old 05-19-2010
TakeFive's Avatar
Originally Posted by mitiempo View Post
The quote below is from RhythmDoctor. He obviously didn't learn much because on another thread he has tagged his bilge pump onto the wire that goes to his pressure water pump. When he leaves the boat and properly turns the switch off his bilge pump will not be active...
I deleted the message you quoted a minute after posting it. I decided to follow my own advice and ignore these unproductive exchanges. It really wasn't so noteworthy that you had to dig it up out of the trash. I should have ignored this sideshow to begin with, and going forward I will ignore any attempts to prolong this worthless discussion.
As for the bilge pump install that you curiously referred to in the wrong tense, I actually have not started on it. I am still collecting information, and I welcome constructive suggestions over on that thread.
I need to correct you on another inaccuracy. I explicitly said that I would rewire the bilge pump so that it was always hot:
Originally Posted by RhythmDoctor View Post
...Although there is not enough space to run another wire along this path, I could attach this wire to the master terminals in the panel (i.e., always hot)...
I could say more, but I think that is, er, good enough.
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
post #64 of 66 Old 05-19-2010
mitiempo's Avatar
RhythmDoctor
You said it and it arrived in my email - not in the trash.
My mistake on the bilge pump. I reread it and you did say you might connect it to another wire that will be always be hot. But without running a second wire I guess the water pump will also be hot all the time. I guess it will be good enough.
Brian
mitiempo is offline
post #65 of 66 Old 05-20-2010
Iroquois MkII
Originally Posted by bljones View Post
Proper maintenance does not require a boat to be out of service for long lengths of time. ironically, deferred maintenance, and years of "good enough" will eventually mean that a boat will have to miss a season, because EVERYTHING will need to be redone, all at once.
Sooooo true.
I'm busting my hump trying to get all the issues caused by the previous owner's lousy "repairs" fixed, so I can get my boat launched in July.
LookingForCruiser is offline
post #66 of 66 Old 05-21-2010
Grasshopper
JiffyLube's Avatar
Well said.
Originally Posted by wind_magic View Post
Interesting thread.
I think people just have different perspectives on the same thing.
To one person the only way to paint the bottom is to use the best paint possible, all the best techniques, put the boat in a good environment to get the best results, and all the rest. That person is trying to perfect the paint job.
Another person might skimp on the paint a little bit, not use the best tools, cut a few corners here and there, etc. That person might be trying to perfect the boat using the money they have available to them, and the paint job is only one of the many things that money has to be used for so they try to get the best bang for the buck.
Yet another person might do a lousy job of painting the boat, just enough to be functional without caring how it looks so long as it works, and they might be reluctant to spend money on the boat in general, just doing the basics to keep her in good working order so that it can be used safely for its purpose. The boat might just be a small part of what the person is dealing with, they may also be cruising long distances, or flying airplanes, or sending their children to college, the boat may just be one part of a much larger picture. That person may be trying to perfect their life, a life that has a boat in it, but isn't just about having a perfect boat with a perfect paint job.
I think this is the core of the "air conditioning vs. no air conditioning" type threads because you have some cruisers out there who believe in maximizing comfort and luxury on the boat, then you have other cruisers out there for whom the boat is only a part of their cruise, many of them are going the distance and buying that plasma display would mean they wouldn't be going to see the pyramids, so they are willing to sacrifice many "must haves" on the boat in order to make room for other things in their lives.
We always get purists on these threads who swear their way is the only way, that it has to be done with the best tools, the best techniques, and they can always justify it by saying that anything less would be inferior, but they are often neglecting to mention the costs involved, what they give up in order to achieve that perfection, etc. I think there is a "good enough" in most cases, it doesn't always have to be the biggest and the best, sometimes the best is whatever works for you.
"Then she lay down in the third bed, and it was just right." - Goldilocks and the Three Bears.
JiffyLube is offline
Very Good Vendor Thread Cruisingdad General Discussion (sailing related) 114 09-21-2014 11:48 PM
Cruising beginner Seanmc Cruising & Liveaboard Forum 7 09-01-2014 11:13 AM
The Salt's Corner Table smackdaddy General Discussion (sailing related) 129 06-18-2013 05:46 PM
Info on a good charter in the BVI's timetasell General Discussion (sailing related) 4 12-17-2010 09:05 AM
Any good places to fill water tanks - Eastern LI Sound? Bene505 Long Island 10 04-23-2010 11:56 AM
