Old 05-13-2010
Klaatu is on a distinguished road
Cabin top winch removal
I have a leak around the bolts that secure a Lewmar 6 winch mounted on my cabin roof. I planned to remove the winch, clean the area and put down a bed of 1/8 butyl tape. However, after removing the bolts I find that the winch appears to be glued to the surface and I attempted to pry the winch loose without success. I simply put a bead of butyl tape around the bolt heads and re-attached.
What is the recommended solution?
Old 05-13-2010
mitiempo's Avatar
It may have been bedded with 5200 which is too agressive a sealant to use. Sometimes you can take a piano wire and saw through the sealant to remove the hardware. The best way to solve the leaking is to remove the winch and rebed properly.
Brian
Old 05-15-2010
GraemeInCanada is on a distinguished road
I agree here, no matter what you should get it off, clean it thoroughly and then bed it properly. That's what I did and while it was a pain to get off (I don't think as much as yours will be), it was well worth the piece of mind that it's been done right and good for a long time.
My blog on boat related stuff:
Old 05-15-2010
Capnblu is on a distinguished road
ya get yourself a piano wire, and wrap it around 2 sticks and pull. Should slice through, apply more muscle if necessary! Grunting seems to help... but nothing beats poor prior installation.
Why, why, why?
Main traveler moved to cabin top GaryT Gear & Maintenance 2 01-08-2007 04:14 PM
Cabin top winch mounting boards larsfis Gear & Maintenance 1 03-03-2003 05:10 PM
It's Winch Servicing Time Tom Wood Gear and Maintenance Articles 0 10-17-2002 08:00 PM
It's Winch Servicing Time Tom Wood Her Sailnet Articles 0 10-17-2002 08:00 PM
Using Winches Safely Sue & Larry Gear and Maintenance Articles 0 08-18-2002 08:00 PM
