Old 05-14-2010
Krow is on a distinguished road
We are repairing minor blistering. After we scrape, grind and fill holes, sand etc. we put on barrier coat.any advice on products and technique?
Old 05-14-2010
Here's a link to a guide booklet for using Interlux's Interprotect product, which is what most people use. A search on Sailnet produces quite a few threads with reference to barrier coats but it would take some reading to find the gems you might want.
http://www.yachtpaint.com/usa/hotlin...paintguide.pdf
In our experience, application is simple, preparation must be complete, and the more coats the better as far as longevity and secure protection goes. (We did 6 - 8 coats on our last boat)
1984 Fast/Nicholson 345
Old 05-14-2010
Freesail99's Avatar
Freesail99 will become famous soon enough
If you search back a little over two years ago, many were using epoxy to coat the bottom of their boats with a barrier coating. Then a non name brand epoxy manufacture started to say on their web site that epoxy paint was better then epoxy resin as a barrier coat and many have jumped on his band wagon. I have not and have used epoxy resin on my boat and I will ask if you have ever tried to sand epoxy resin off of something and if you have tried to sand epoxy paint again off of something. Enough said?
S/V Scheherazade
Epoxy Barrier Coat over Gel Coat? lizardheadone Gear & Maintenance 2 01-17-2010 08:52 PM
DIY Barrier Coat mrybas Gear & Maintenance 39 12-05-2009 11:33 AM
Barrier Coat & Antifouling paint shipley Gear & Maintenance 7 08-09-2009 09:18 AM
Barrier Coat stupidgringo Gear & Maintenance 0 08-23-2001 04:53 PM
Epoxy Barrier coat stevemorrell General Discussion (sailing related) 3 11-07-2000 02:13 AM
