05-14-2010
the easy option is to bed it with 4200 and just wipe of the excess with your finger and call it good
the harder option is to build up a flat spot with thickened epoxy, then bed it with 4200.
you could also sand a slight flat spot for it, say split the 1/16 difference. the backing plate should be epoxyed on so no real loss in strength. then bed it in 4200
get the hint yet, just bed it with 4200 filling the gap you will be using it anyway and 1/16 inch is not a big deal.
