Old 05-15-2010
moonie5961's Avatar
1974 Contest 31'
moonie5961 is on a distinguished road
An idea. Probably bad.
removed
Old 05-15-2010
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
Which boat make/model do you have that has teak rub rails? Might be a good idea to put that information in your profile or signature or somewhere.
I ask because my Tartan 27' has teak toe/cap/rub rail as well.
Are you planning on painting the decks or the free board of your boat?
You might as well try the 333 solvent. You have nothing to lose.
Old 05-15-2010
Ulladh is on a distinguished road
Gelcoats can take a lot of abuse, after the paint chemical strip rinse well, dry and sand.
Before painting I would suggest an epoxy penetrating sealer, "Progressive Epoxy" has a low solvent penetrating epoxy, then light sand the epoxy sealer before painting.
If air temperature is above 80 deg F be careful, mix the epoxy in small batches in new containers each time.
Old 05-15-2010
deniseO30's Avatar
Lies about her age
remove the rub rail.. do it right.
Now here's a really bad idea CoastalEddie Gear & Maintenance 61 01-10-2010 12:29 AM
Bad alternator??? cgha33 Gear & Maintenance 11 10-12-2006 04:56 AM
BAD IDEA shift/throttle firemanbob55 Gear & Maintenance 4 08-08-2005 04:34 PM
Recovering from Bad Starts Dean Brenner Racing Articles 0 05-29-2002 08:00 PM
Good Lanes and Bad Lanes Brad Read Racing Articles 0 04-25-2001 08:00 PM
