PSS Clamp Collar now available from PYI - Page 2 - SailNet Community
post #11 of 17 Old 05-18-2010
T37Chef's Avatar
Originally Posted by rbarkas View Post
Was this the one you got from McMaster?
Yes, per MaineSail's suggestion.
Cheers,
Shawn
S/V Windgeist
1982 Tartan 37C
T37Chef is offline
post #12 of 17 Old 05-18-2010
A New Adventurer
funjohnson's Avatar
I have a zinc right before my prop strut... seems to be the same concept.
1989 Sabre 34II Targa
mjsailing.com
funjohnson is offline
post #13 of 17 Old 05-18-2010
Gene T's Avatar
I hope that is not what you meant. A zinc in front of the strut will interfere with water flow and cooling in your cutlass bearing. Not a good thing.
This discussing is about preventing the PSS collar from sliding forward due to the pressure from the bellows and hence causing a leak.
Gene
Currently in Long Beach, CA
Gene T is offline
post #14 of 17 Old 05-18-2010 Thread Starter
Tanley's Avatar
Was looking for set screws and saw this on their website. Looks like they're live parts now.
PYI Inc. Max-Prop PSS Shaft Seal Seaview Radar Mounts R&D
Tanley is offline
post #15 of 17 Old 05-18-2010
A New Adventurer
funjohnson's Avatar
Gene
How far infront? The zinc is about 12" in front of the strut... midway between the exit of the stuffing box and strut. This will alow the shaft to come about 12" out, but still within reach from inside the boat.
mjsailing.com
post #16 of 17 Old 05-18-2010
SanDiegoChip's Avatar
We put a zinc in the same place just forward and up against the PSS on the shaft.
SanDiegoChip is offline
post #17 of 17 Old 05-18-2010
Gene T's Avatar
No problem then. An inch would be enough. If you are using it to keep the shaft from coming out then I would keep it close enough to prevent the prop from hitting the rudder if it actually did come out.
Gene
Gene T is offline
Who has PSS shaft seal installed? orientalnc2010 Pacific Seacraft 6 04-25-2010 07:03 PM
PSS Dripless Shafts or others? chef2sail Gear & Maintenance 34 04-24-2010 04:47 AM
PSS Dripless Bearing weephee General Discussion (sailing related) 2 04-06-2010 12:38 PM
Mast Collar spang36 Gear & Maintenance 2 11-21-2009 02:17 PM
Packless Shaft Seal (PSS) bkdehuff General Discussion (sailing related) 4 04-20-2004 06:41 PM
