05-20-2010
Iroquois MkII
If you do go ahead with putting in the hole, I wouldn't advise just filling the hole with epoxy - you want to grind out the edges and do a proper fiberglass patch. Plenty of posts on how to do that.
Honestly I see the attraction in putting in the hole in the hull. But what might make more sense is to fill the holes where the hardware used to be, with epoxy. Over drill the hole with a larger bit, use a router bit to remove deck core between the fiberglass layers, and then fill with epoxy. When you're ready to reinstall deck hardware, you just have to drill the hole & bevel it, and you're done.
If you're going to be recoring the deck though, don't bother, just cover the holes with duct tape or something. That pillar of epoxy wouldn't make the recore job any easier.
