Old 05-21-2010
preservedkillick is on a distinguished road
New Prop & Shaft - install prop questions
Hey everyone,
I just got a new Campbell Sailor prop and a new stainless shaft. Not sure I installed it correctly (or I'm being too fussy).
Here's what I did:
  1. Key looks good with rounded edges, slides easy in both shaft and prop.
  2. Prop fits well on taper, no rocking.
  3. Slide prop on shaft w/o key and mark shaft with a sharpie at highest point
  4. Remove prop, put key on shaft, slide prop on..couple of mm away from my line
  5. File top of key a little..try again..still a couple mm away from my line
  6. Repeat filing key and testing a few times..still can't reach the line..and now if I shine a light I can see a gap between key and prop keyway.
I can't understand what's holding the prop from sliding back to the line? Should I remove some width in the key? Key slides well in both keyways.
Now that I've got some space between the key and the top/bottom of the keyways, should I get a new key and start over?
If I give the nut a turn with a wrench I can hit my line, but not without the wrench.
Am I over-thinking this?
And, I can't find any info on the proper torque for the prop nut. I've seen everything from 10 to 100 foot pounds.
-PK
Preserved Killick
Seagrass
Boothbay Harbor, ME
Alberg 30:
Old 05-21-2010
T37Chef's Avatar
Senior Culinary Member
T37Chef will become famous soon enough
BTW, the small prop nut is to go on first, followed by the larger...most do it back wards You may want to confirm that with Norm
Shawn
S/V Windgeist
Tartan 37C #358
Photo by Joe McCary
THE Yacht Builders List:
Useful Food Purchasing Links:
Old 05-22-2010
JimsCAL's Avatar
JimsCAL is on a distinguished road
I would say as long as you can drive the prop fully on with the nut you are OK.
Help! Metric prop shaft creating road block! 1972 Dufour Arpege. lawsonmitchell Gear & Maintenance 24 03-04-2010 02:34 PM
Pulling E-42 prop shaft xort Endeavour 0 01-25-2010 10:49 PM
1 inch prop on 25mm prop shaft? lawsonmitchell Gear & Maintenance 2 11-28-2009 02:19 PM
Choosing the Right Propeller Sue & Larry Gear and Maintenance Articles 0 02-04-2003 07:00 PM
Drive Train Vibration Tom Wood Gear and Maintenance Articles 0 10-10-2002 08:00 PM
