05-21-2010
Sounds like you could be using poly resin, but the problem is similar with epoxy.
As soon as you mix in the hardener, the reaction starts. This generates heat. The more heat that accumulates, the faster the reaction occurs. The more liquid you have in your container, the slower the heat generated can radiate away...
So, if you need to mix a larger batch, use a wider container or tray that lets the resin spread out and thereby let heat radiate off quickly.
Sidebar: a friend of mine once had a fairly large amount of glass to lay, and had no experience with epoxy... so he mixed the whole quart with the hardener... in one coffee can. Very shortly it started to smoke, and he had to toss it over the side!
Several small, well-spread-out batches are better.
Cheers,
L
