05-24-2010
The way I see it is that you have to replace what you use so no matter how big your bank is, you have the same problem. The bigger the bank the longer you can deplete it but the longer it takes to recharge. What comes out has to go back in. If you can run between 50% and 90% of capacity through a 24 hour cycle, that's not a bad situation. On a 14 sunlight hour day you're probably getting from your solars, better than 250Ah back in a 24 hour cycle (can that be right? sounds too good to be true!)
If your tow generator does it for you while you're sailing the the wind gen will not be a great help because when you're on anchor, by design you will choose the quietest spot and the wind gen will be of little value.
But having said that . . . . the tow gen is probably taking a little out of your boat speed (maybe a half a knot?) and a wind gen won't. So if you don't mind spending a little longer at sea on a voyage then that also doesn't matter. But remember, on a three week voyage the difference in boat speed noted above means an extra 2 days at sea.
I would personally rather run a wind gen than a tow gen. My choice is the Rutland 913 simply because it is really quiet. Yes I know there are wind gens that are reputed to be able to power a small town but they come standard with ear muffs!!
Arthur C. Clarke
