Old 05-24-2010
outdoorsman37 is on a distinguished road
Best way to clean hull?
Hello, I just bought a 21 sailboat and pulled it out of the water. the hull is pretty dirty with tough cr*p on it. There are some shell type clinging on. maybe it was from some shells that were previously scraped off. the whole bottom is pretty caked with growth. I broomed it down to just what is stuck on there. So, what is the best way to clean it without damaging the hull? I would like to eventually paint it but may not want to do it now unless that would be best. It is on a trailer. Pressure wash, sand blast, some cleaners, rotary sander, I really don't want to scrap the whole hull with a small scraper. That would take forever and a lot of work. Anyone have a suggestion for the easiest and best way to clean it up? Something that saves time and doesn't damage the hull?
Thanks!
Old 05-24-2010
mike dryver is on a distinguished road
check with some one that does soda blasting it sounds like you have calcium build up from shell fish or barnacles you could try vinegar soaking with rags it might dissolve the calcium.
Old 05-24-2010
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
Small scraper. What kind of paint do you have? If there's paint left, you shouldn't need to scrape that hard. Otherwise, it's attached to the barrier coat or gelcoat. In which case, strip and repaint the entire hull.
I used an orbital sander and probably 80 discs to take mine to gelcoat after a bad season of barnacles. The new bottom is almost a full knot faster.
Merit 25 # 764 "Audrey"
Tips For Compound, Polish & Wax Maine Sail Gear & Maintenance 172 1 Week Ago 05:50 PM
Wax or polish Jotun Gear & Maintenance 58 06-26-2009 01:54 PM
Spring Hull Cleaning Tom Wood Gear and Maintenance Articles 0 04-05-2004 08:00 PM
Hull Speed Demystified Steve Colgate Learning to Sail Articles 0 06-10-2000 08:00 PM
Hull Speed Demystified Steve Colgate Buying a Boat Articles 0 06-10-2000 08:00 PM
