05-24-2010
I think Gene's post is very plausible. Where do you sail?
If the shaft was heated, and then rapidly cooled, it could indeed have made the steel brittle to the point of failure. For example, a lot of engine use (heating) in very cold water (rapid cooling when you stop). I would guess that repeating this cyle would increase the hardness of the metal to such an extend that the torque driving the propeller would break it.
You could probably do a 'quick and dirty' test yourself using a file. I am no metallurgist, but I know that different alloys of steel vary in their susceptibility to this kind of failure.
