Cleaning / Washing Sails - Washing Machine ? Bleach ? - Page 2 - SailNet Community
post #11 of 14 Old 05-27-2010
STARBOARD!!
KeelHaulin's Avatar
As I said before BE CAREFUL. Washing with a pressure washer is NOT being careful. You will blow holes in the fabric and destroy the resin that is in the fabric to keep it crisp and tightly woven. Holes in the fabric will reduce the pressure differential across the sail surface and it will result in a "blown out" sail. Remember; the sail needs to be air-tight; and blasting water through it will surely damage/destroy this.
Also; try not to use too much oxalic; remember it is an ACID. Use it sparingly; and if the stain won't come out; just live with it. The stain is doing less damage to the sail cloth than the cleaner.
KeelHaulin is offline
post #12 of 14 Old 05-27-2010 Thread Starter
Thanks for all the replies and advice. Keep the ideas coming.
Dennisail is offline
post #13 of 14 Old 05-28-2010
Seņor Member
ottos's Avatar
Have you tried a sail loft? More expensive than a washing machine - but it's another option.
ottos is offline
post #14 of 14 Old 05-31-2010
Can send them off to Sailcare and have them cleaned and re-resinated by the pros, then clean them yourself with Detergent and water.
garyguss is offline
Basic Sail Care for the Boat Owner Dan Dickison Gear and Maintenance Articles 13 05-19-2015 04:52 PM
spinnaker maintenance QuickMick Gear & Maintenance 3 11-17-2009 01:42 AM
Sail Care and Cleaning Kathy Barron Gear and Maintenance Articles 0 10-20-2003 08:00 PM
Cleaning Sails Sue & Larry Gear and Maintenance Articles 0 06-09-2002 08:00 PM
Cleaning Sails Sue & Larry Gear and Maintenance Articles 0 09-18-2001 08:00 PM
