05-26-2010
Originally Posted by sundog01
I've had the boat 3 years and don't really know how old the furling system is. I have to use 2 hands to spin the swivel - so I'm thinking that is too tight. My guess is that the drum and all have to come off to replace that piece. Any hints? Thanks for your time.
The swivel can be removed from the top by removing the washer that holds the top luff bearing in. Or it can come off the bottom by removing the drum and feeder.
If the system is still on the mast, the best bet is to take it off the bottom.
The bearings may have gotten some moisture in them causing a little rust to form which would likely cause them to stiffen up.
Could you take a picture or two of the swivel laying next to a tape measure. There is a chance that I have one but I need to know the exact dimensions.
Ron Paul 2012
"wikijar"
