What went bad SV? you can just get a new condenser if the evap coil is still good (most likely is)
Well... Let's see. Seven years ago my daughter used a steak knife to free an ice-cream bar from the evaporator plate (box) with the predictable hole a result. Fixed that with Marintex and an epoxy patch that has, remarkably, held up reasonably well although if the plate defrosts, it does leak a little; and,
After 24 years the copper coolant lines to the evaporator have developed pits due to exposure to marine air and there are now several tiny holes in these--albeit patched with epoxy--that also slowly allow Freon to escape (we need a re-charge about every 12-18 months); and,
The thermostat has died (I can jumper around it with which the compressor tries to start) so that needs replacing; and,
The compressor now rattles like heck as it tries to start although, if you give the case a well placed bang with a spanner, it will start and run, albeit with much ratteling and groaning while it gets hot to the touch; and,
The control module died about 10 years ago and was replaced with a generic version that won't work with the current era Danfoss compressors;
So, I need a new evaporator, compresser, thermostat and control module.
Sometimes ya' just got'ta know when to hold... and when to fold. Moreover, the new units are so much more efficient now I should come out ahead in energy savings, no?
s/v HyLyte
