Old 05-28-2010
QuickMick's Avatar
QuickMick is on a distinguished road
rope ladder
Im making a rope ladder for the dock. Im thinking of using dowel rods and securing them with double constrictor knots, but am interested in making one out of rope only. anyone know a good method for this or a place i can find one?
happy memorial day
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 05-28-2010
knothead's Avatar
happy memorial day
Stormdrane's Blog: A Rope Ladder
Ron Paul 2012
"wikijar"
Old 05-28-2010
paulk's Avatar
paulk is on a distinguished road
Careful with the rungs
Dowels might not be the best things to use for the rungs. They are often made with little concern for the grain pattern, so the grain runs out of the piece instead of going it's whole length. This weakness will give you a rung that is liable to crack when you put any real weight on it. Oak stair handrail material might be better. You'll be able to see if the grain runs out, and the grain tends to run more parallel to the sides in handlrails. It's also important to orient the rungs when you tie them so the parallel lines of the grain are on the top and bottom. Wooden baseball bats are used with the label up for the same reason. All-rope might be a lot simpler!
Old 05-28-2010
knothead's Avatar
I bet an old shovel or hoe handle would be a good material.
Ron Paul 2012
"wikijar"
Old 05-29-2010
tager's Avatar
tager is on a distinguished road
I bet schedule 40 tubing would work fine if you get the aspect ratio right. Thick tubing on a short rung.
Old 05-29-2010
paulk's Avatar
and lighter and less rot-prone than wood. The also-mentioned tool handles could work. They're often made of ash or hickory, as well as oak. At about $10 each, (I just got one to replace an umbrella post that got snapped in the wind) you're looking at an expensive ladder that requires a good bit of maintenance too.
Possibly a stripped halyard? SiXeVeN Gear & Maintenance 9 06-12-2011 11:00 PM
Butyl Tape = Rope Caulk? Tanley Gear & Maintenance 18 05-26-2010 09:02 AM
dinghy ladder MarkCK Gear & Maintenance 17 03-05-2010 11:00 AM
Ladder question mcain Gear & Maintenance 14 08-03-2007 10:28 PM
How to size rope ModMMax Gear & Maintenance 41 12-12-2006 12:16 AM
