Old 05-30-2010
FishFinder's Avatar
FishFinder is on a distinguished road
Gluing/Welding Cracked Lexan/Acrylic Hatch?
What is the best way to reattach a cracked piece of lexan/acrylic? This is a chunk of my companionway sliding hatch that has been broken for years, I have used special glues that hold for a couple months but break free eventually. Wondering if there is something more permanent like a way to weld the piece back on ... ?
1980 S2 9.2A (30') in Anacortes, WA
Aux power 13hp Volvo MD7A
Old 05-30-2010
paulk's Avatar
paulk is on a distinguished road
However you glue or melt the piece back in place, the crack will always look crummy. It sounds like UV degradation (and possibly flexing) is making the repair come apart each time you try to fix it. The best approach fix might be re-glue the broken piece in place and then cover it with a strip of teak, another plastic, or some other material that goes with the boat, glued and mechanically fastened. Five or six small countersunk machine screws pointing up, with acorn nuts on the top would do the trick. That way the broken piece won't be visible and won't come off again.
Old 05-31-2010
Mickstr6 is on a distinguished road
Gorilla glue... ?
I used gorilla glue on my plexi hatch cover. Used clamps and let it set overnight. Seems sound, but time will tell.
forward hatch leak joec43 Morgan 5 12-22-2006 05:31 PM
Effectively sealing forward hatch Petar Gear & Maintenance 9 01-27-2006 08:07 AM
Resolving Hatch and Portlight Problems Tom Wood Gear and Maintenance Articles 0 03-17-2003 07:00 PM
Dodging Pirates in Southeast Asia James Baldwin Cruising Articles 0 02-28-2002 07:00 PM
Hard to Open Sliding Hatch sjacovino Gear & Maintenance 6 02-13-2002 07:29 PM
