Tiny Dehumidifiers - Page 2 - SailNet Community
 2Likes
post #11 of 50 Old 06-26-2010 Thread Starter
TakeFive's Avatar
The dehumidifier has been in for a few weeks, and continues to remove about a quart of water per week. I have removed all the Damp-Rid stuff - glad not to have the corrosive liquid leaking out from the countertop canister, and the awful perfume smell from their closet hangers.
Someone asked for some pictures, and I finally got a couple. The first shows what the front of the unit looks like. But since the water reservoir and on-off switch are both on the back, I velcro-ed the thing, facing backwards, to the forward fiddle of my galley storage shelf (see second pic):
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
post #12 of 50 Old 06-26-2010
jarcher's Avatar
Thanks for the update! Did you say it can run on 12VDC? In a post you said the display model had a 12VDC wall cube but your pic seems to have a 110VAC cord.
Either way, I think I need one of these!
Helios
Scampi 30 MK-IV
jarcher is offline
post #13 of 50 Old 06-26-2010 Thread Starter
TakeFive's Avatar
The cord in the pic looks like a 120v cord, but it's actually carrying 12v from the power brick. If you wanted 12v operation, I suspect that you could easily tap into that cord with a 3-way switch (A-B-off) to provide a selectable power source. That would be much more efficient than using an inverter to go 12 VDC → 120VAC → 12 VDC.
I have no interest in 12v operation at this time. Either I'm at the dock with shore power, or I'm sailing with the companionway open. If you're at a mooring ball I can see how you might run this off a solar cell, although the power brick is rated at 60w IIRC, so you'll need a hefty cell.
Be aware that the internal fan is a little noisy, and the thing puts out some heat, so operating while you are in the cabin for an overnight might not be preferable. I just use it for while I'm away during the week.
TakeFive is offline
post #14 of 50 Old 06-26-2010
jarcher's Avatar
No I would wire it directly from my 12VDC circuit panel. I have only one spare circuit from my 120VAC panel, but several spares from my 12VDC panel. I would just run it when the battery charger is powered up from shore power.
Thanks!
Helios
Scampi 30 MK-IV
jarcher is offline
post #15 of 50 Old 06-27-2010
nightowle's Avatar
I have a similar unit (the Eva Dry) as mentioned above. It's been working fine for the past several months and the container can fill in several days here in the PNW. It's very, very quiet, so I guess better than the Home Despot brand above. I'm going to rig up a tube at the top of the container so it will just pump the moisture into my sink drain and also use a timer so it won't be running 24/7.
________
S/V Don't Panic!
O'Day 27
Seattle, WA
“Navigare necesse est, vivere non est necesse” To Sail is vital, to live is not.
nightowle is offline
post #16 of 50 Old 06-27-2010
RD—
Just curious, why don't you leave it running in the sink... it looks like if you removed the tank, it would just dump water directly into the sink. Or if that makes you nervous....rig a hose to the output pipe that appears to be inside the tank, and then leave it sitting on the counter with the hose in the sink.
sailingdog is offline
post #17 of 50 Old 06-27-2010
Would it be possible to put it over or in a larger bucket that could be drained out of the boat. That would be perfect for those of us that don't get down to the boat every weekend during the winter?
Harris
S/V Phoenix
1976 Catalina 27
15hp Honda 4 stroke
Columbia River
Port of Kalama Marina
Kalama, Wa
Survivor is offline
post #18 of 50 Old 06-27-2010 Thread Starter
TakeFive's Avatar
The dehumidifier has both a sensor to ensure that the tank is in place, as well as a float switch to turn it off when the tank fills up. So the best way to drain directly into the sink would be to install a tiny "through-hull fitting" in the back of the tank and attach a tube to run to the sink (or just put it in the sink).
I had been planning to do this, but it is way down on my very long list of more important safety improvements. Plus, lately I've been there to empty it out at least a couple times a week.
My basement dehumidifier is rigged to empty into a sump so I don't have to empty the tank. Unfortunately I have had two of them fail in the last 5 years, and they ran for [weeks? months? years?] before I noticed. (I discovered the most recent failure when I stuck it in my boat and got no condensation in the pan for a couple weeks.) So I try to run everything off the tank for at least a couple muggy weeks out of the year so I can gauge the rate of moisture removal.
TakeFive is offline
post #19 of 50 Old 06-27-2010
RhythmDoctor
I have been running a small dehumidifier much like yours in my 26 foot sailboat here in Melbourne, Florida for the past two months. The temps and humidity here have been terrible for the past month or so. I drilled a hole about 1/3 up from the bottom in the plastic reservoir and put it in the sink. I figure I can put a cork in it if I need to. Anyway, it is running like a champ! I closed off the nicro vent and the bilge has been dry for a while now. I think this was one of my "way better" ideas. Good luck with your unit.
robinlyn3 is offline
post #20 of 50 Old 06-27-2010 Thread Starter
TakeFive's Avatar
I have been wanting to put in a nicro vent for awhile, and this was my stop-gap measure while I figure it out. I have a good place to put one vent, but you need both in and out vents to make it work right. I do not have a really good place to put a second vent - unless I remove a redundant bulkhead compass (shown in the upper left of my profile pic) and replace it with a cowl vent. But this stopgap measure may be better anyway. My bilge has always been bone dry, but I have an outboard, so no packing gland to worry about.
TakeFive is offline
Quick Fix for tiny leaks? QuickMick Gear & Maintenance 7 10-26-2009 05:42 AM
lots little tiny blisters??? obiec Gear & Maintenance 11 08-30-2009 06:56 PM
Tiny Palau tries to balance development, environment (The Philadelphia Inquirer) NewsReader News Feeds 0 05-07-2006 04:15 AM
Tiny rust spots from nearby grinders VIEXILE Gear & Maintenance 7 04-09-2004 05:22 AM
tiny leak in black iron fuel tank kathyspike Gear & Maintenance 2 11-17-2002 12:05 PM
