Tiny Dehumidifiers - Page 3 - SailNet Community
 2Likes
post #21 of 50 Old 06-27-2010
jarcher's Avatar
So for a boat that has the Nicro vents already, is this a bad idea, since we're just dehumidifying the moist air from outside?
Helios
Scampi 30 MK-IV
jarcher is offline
post #22 of 50 Old 06-27-2010 Thread Starter
TakeFive's Avatar
I am not an expert, but I would think that this is the case. You're bringing in new air from the outside anyway (and that is a good thing), and that would probably overwhelm any dehumidification that you did.
Rick S., Swarthmore, PA
TakeFive is offline
post #23 of 50 Old 06-27-2010
The reason you put Nicro vents in place is to help prevent boats from becoming moisture pumps. As a boat heats up during the day, the air absorbs more moisture—since hotter air can hold more water. When the sun goes down, and as the air cools, then the additional water can condense out. By keeping the air flowing, the air doesn't tend to act as a moisture pumps, since it keeps the boat from heating up as much and moves the heated air, which holds more water vapor in it, out of the boat.
sailingdog is offline
post #24 of 50 Old 06-27-2010 Thread Starter
TakeFive's Avatar
I agree for the most part. But if the boat is well-sealed, and there are no pools of water to evaporate in the heat (i.e., bone dry bilge), then there is no source of moisture for the air to absorb when it gets hot, and thus no condensation when it cools.
So there are two extremes, both better than the alternatives:
  1. Good ventilation that prevents condensation when the boat cools
  2. Seal off the boat and dehumidify the stagnant air aggressively
I agree that option 1 is preferred, but if like me you do not have a good location for a second vent (yet), then option 2 may be a viable alternative
This is a similar argument to the settee locker condensation issue in a separate thread that I started. And by the way, I checked for condensation in my settee lockers last week and they were still completely dry.
TakeFive is offline
post #25 of 50 Old 06-08-2011 Thread Starter
TakeFive's Avatar
Finally, after a whole year, Home Depot has the one I purchased on their website. It says internet only, though:
Perfect Home 4-Pint Dehumidifier - EWDH4 at The Home Depot
TakeFive is offline
post #26 of 50 Old 06-08-2011
Irrationally Exuberant
Thanks for staying on top of that, RD. So the unit is still working for you?
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #27 of 50 Old 06-08-2011 Thread Starter
TakeFive's Avatar
Still works great for my boat, which is pretty water tight and only 25'. A larger boat may need more than one of these.
TakeFive is offline
post #28 of 50 Old 11-02-2011
Asleep at the wheel
jimgo's Avatar
RD,
I'm torn between dehumidification and the Nicro vents. The dehumidification seems a good way to solve the problem of moisture in the cabin. However, unless I rig the dehumidifier to empty into the sink or another container (which then re-introduces the water into the air), it sounds like I'll have to make a weekly trip out to the boat to empty the tank. Knowing my personal schedule, I don't think that's likely. So, I'm stuck having it empty into a bucket (again, with the potential evaporation issues that brings with it) or empty into the drain. Not exactly a deal breaker, but it seems somewhat counterproductive. I'm OK with the shore-power only issue; I'll mostly be doing day sailing and occasional overnights, and most of the overnights will be at the dock, so that's not a big deal. The dehumidification should also make the air in the cabin feel cooler, which is good for the shore in the summer.
By contrast, the Nicro is solar powered and runs (essentially) constantly. I don't know that you need a second Nicro (on my C25, the companionway cover has vents, and the pop-top and hatch have areas where the air can easily enter), though I can certainly see where having a second one would make things even more efficient. The Nicro helps encourage air flow through the cabin, thus allowing the humidity levels inside and outside the cabin to remain relatively equal, which in turn reduces the condensation within the boat. There's nothing to empty, and I don't have to worry about float switches that don't trigger (not that a pint of water is really going to be a killer). The Nicro will also help move dryer air into the cabin, thus allowing for more effective evaporation of any water that may be in the bilge. Of course, unlike the dehumidifier, the Nicro won't make the air feel cooler (it doesn't move enough air to be a true "fan"), and it only ever dries out the cabin to the point where it is in equilibrium with the outside air. One Nicro is about $160, so about 3x the cost of the dehumidifier. That makes the dehumidifier very attractive, but I'm still not completely convinced. Can you help convince me? []
Also, what do you do over the winter? Are you back to Damprid?
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #29 of 50 Old 11-02-2011 Thread Starter
TakeFive's Avatar
DampRid is what I use in the winter. Even if I had a Nicro vent, I'd need to do DampRid in the off season because my boat cover would block the sun.
For the dehumidifier, you can just drill a hole in the back of the pan and put it in your galley sink. Then you don't need to check it weekly. If you want to be a little fancier, glue a small hose barb into the pan and attach a Tygon hose into the drain - then your sink won't even get wet. I have not done this because so far I've gone to the boat frequently and wanted the water available to top off the battery if it needed it. But I will probably drill the hole next season.
I actually ordered a Nicro vent from WM but the order never come in due to a recall due to defect. I read around a little and learned that their batteries wear out pretty frequently. Then I remembered that when shopping for boats, the ones that had Nicro vents were never operating. I came across this Peltier-type dehumidifier by chance and decided to try it instead, and I've been happy with it ever since.
You are correct, I would not need a second Nicro vent. Since I posted that, I've realized that my boat has enough "little leaks" that there would be enough fugitive exhaust if I had one Nicro vent blowing in.
TakeFive is offline
post #30 of 50 Old 11-02-2011
tommays's Avatar
As i am on a mooring electric is not gonna happen
dorade boxes and hatch boards with water proff vents move a lot of air
My Nicro spins a LOT but moves nothing compared to the dorade boxes
The Cal 29 has a deep section in the bilge and it allows the boat to have a tiny amount of standing water to make smells
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
Quick Fix for tiny leaks? QuickMick Gear & Maintenance 7 10-26-2009 05:42 AM
lots little tiny blisters??? obiec Gear & Maintenance 11 08-30-2009 06:56 PM
Tiny Palau tries to balance development, environment (The Philadelphia Inquirer) NewsReader News Feeds 0 05-07-2006 04:15 AM
Tiny rust spots from nearby grinders VIEXILE Gear & Maintenance 7 04-09-2004 05:22 AM
tiny leak in black iron fuel tank kathyspike Gear & Maintenance 2 11-17-2002 12:05 PM
