06-13-2010
I've never been struck by lightning (time to buy a wooden boat) but I doubt that running a wire down the mast to the winch, or keel, will do much to protect you from the strike. The amperage is beyond anything you can compensate for, the voltage and charge will go where it wants, not where you want it to go, and the EMP will kill almost every electronic item on board.
Are you inviting a strike by having a well grounded point high in the air? Don't know. Are you more protected by having your vessel at a voltage potential closer to the surrounding area? Don't know that for sure either.
I've seen lightning strike a boat in the middle of a marina, taller and shorter sticks all around. To me the best place to be is out of an area of lightning activity. If you can't do that, then the odds of getting hit, or not, are beyond your control.
Capt. Douglas Abbott
USCG/MCA IV/C.I./M.I. 500-ton Oceans
PADI MSDT
