Old 06-01-2010
k47kaverns is on a distinguished road
Water in collecting in Hull of Force 5
Hey Guys,
I'm a beginning sailor starting on a Force 5. Last season when I put the boat away for the winter, I noticed a sloshing of water in the bottom of the hull. Maybe a couple gallons. I've flipped the boat over and I've opened the drain with no luck with getting rid of the water. Any suggestions on how I can get rid of this water in the hull? And any advice on how to keep it out of there.
Thanks for your help - kyle
Old 06-02-2010
14432's Avatar
14432 is on a distinguished road
There are pieces of foam floatation inside the hull that could be preventing the water from getting to the drain. There are two options. Sometimes the water moves more easily fore and aft. Try tilting the boat so that the bow is higher than the stern - the more tilt the better. If the water runs aft (you'll hear it) then the best approach would be to drill a drain in the transom into which you can put a removable/screw-in drain plug.
If that does not work then it may be necessary to install one or more 4" inspection ports so that you can look inside the hull to see what's happening.
Before you do any drilling, it would be a good idea to find where the boat is leaking and fix that. Mix some soapy water and sponge/brush the deck (especially where hardware is attached), hull, hull/deck joint, and centerboard trunk. Then use a shop vac, hairdryer, tire pump or some air source to blow air into the drain hole while someone examines the boat looking for bubbles. Where air comes out, water is getting in.
Old 06-02-2010
14432's Avatar
Forgot to add...............once you figure out the source of the leak report back and we'll go from there regarding the fix.
Old 06-02-2010
Hey,
I really appreciate your response. I'm going to give that a shot this weekend. Let you know how it works out. -kyle
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 02:42 PM
MacGregor 26 vs. ? jiml2p Boat Review and Purchase Forum 184 08-30-2011 08:10 PM
High Tech vs traditional-Comments? Pangaea General Discussion (sailing related) 38 08-07-2007 01:07 AM
Gifts from the Rain Gods Doreen Gounard Her Sailnet Articles 0 03-18-2004 07:00 PM
Beyond the Bucket Brigade Brian Hancock Seamanship Articles 0 01-01-2003 07:00 PM
