Advice from Boatyard on Mounting Radar - Page 2 - SailNet Community
post #11 of 13 Old 06-03-2010
Maine Sail's Avatar
Originally Posted by cvsheppard View Post
I thought this would be a quick and easy install, but I can see different now. Thanks again for all the input.
Quick & easy......???? On a boat???? No such thing..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #12 of 13 Old 06-03-2010
STARBOARD!!
KeelHaulin's Avatar
You might consider contacting a marine electronics company and asking if they can do the installation with the mast up. Or call a rigging company. Being in Portland there should be someone who can do this work correctly without pulling down the stick.
JMHO...
KeelHaulin is offline
post #13 of 13 Old 06-03-2010
Thank you everyone for your points of view. After thought and review of your comments I will have the mast dropped and radar maounted in that fashion. For those that asked, I do have an internal conduit for wires but no internal halyards and I have 2 retrieval lines already in place, one to the top of the mast and the other midway up where the old radome was mounted. I thought this would be a quick and easy install, but I can see different now. Thanks again for all the input.
If you have a conduit with a messenger and there is enough room in the conduit to run the radar cable you can certainly do the job without pulling the stick.
That doesn't mean that it wouldn't be easier, safer and perhaps even less expensive to pull it and do it on the ground.
There are lots of variables and unfortunately, you only find those variables when you are in the middle of the job.
I think you have made the best choice. Like Maine says, there is always other things you can do while you have the mast down.
Plus, assuming that you are having the work done, you will be able to check out the workmanship yourself with the mast down.
I had to chuckle at the quick and easy comment too.
knothead is offline
Navigating with Radar Jim Sexton Seamanship Articles 0 03-29-2002 07:00 PM
Radar Basics Jim Sexton Seamanship Articles 0 11-14-1999 07:00 PM
Radar Basics Jim Sexton Gear and Maintenance Articles 0 11-14-1999 07:00 PM
Radar Basics Jim Sexton Cruising Articles 0 11-14-1999 07:00 PM
Radar Basics Jim Sexton Her Sailnet Articles 0 11-14-1999 07:00 PM
