06-05-2010
I think
I saw a Smackdaddy post saying that pics were not working. For your spin halyard, it really does need to be above the forestay. Otherwise you can do exciting things to your spinnaker and/or forestay fittings at the hounds when you gybe. We rigged a Harken block on a swivel for the spinnaker halyard on our Soling and ran the line through it down to both sides of the mast, outside, so that we'd be able to set to port or starboard without having to throw the (internal halyard) end around the forestay. Attaching the block to the mast may be the hardest part for you. Is there a tang or exit hole where you would need it? Bolts or screws may pull out or shear - make sure they're hefty enough. Shackling the block in place is the best, if you can something good to attach it to.
