Old 06-04-2010
mrybas's Avatar
mrybas is on a distinguished road
Small seacocks?
Does anyone make seacocks smaller than 3/4'' (like 1/2'')? I have salt water intake for the galley foot pump that is currently 3/8'' with a ball valve, but would like to be able to bolt to the hull with a seacock. It's in a locker that will like be full of canned food bouncing around.
Old 06-04-2010
garymcg's Avatar
garymcg is on a distinguished road
I just replaced a 1/2" thru hull/seacock with 3/4" because I wasn't able to find anything smaller. The old thru hull was flush on the outside, an appropriate sized hole saw for a 3/4" fit over the entire flange of the old 1/2" so I cut it out from the bottom which made installing the 3/4" a piece of cake.
Old 06-04-2010
CS271409's Avatar
CS271409 is on a distinguished road
Forespar has a 1/2" seacock in Marelon. I have a couple of Marelon seacocks on my boat and they have proven to be robust.... strong enough to counter flying cans of pork and beans?? Not sure.
Here's a link.
Forespar Seacock - Pride Marine - Ontario Canada
Dave S
Georgian Bay, Ontario
Catalina 34 - (formerly CS27) "Good Idea"
Old 06-06-2010
TommyD's Avatar
'74 C&C 33'
TommyD is on a distinguished road
Seacocks vs Ball valves..
I understand bolt-on seacocks are used instead of ball valves, but given that thru hulls have a nut holding them in place how do the seacocks install? I've had my C&C for a half dozen years & it came with ball valves installed. Even the 2 last original gate valves which I am not removing simply thread onto the thru hulls, no flanges.
TD
'Nora Mae Rose'
Portsmouth, RI
Old 06-06-2010
CS271409's Avatar
TommyD,
Seacocks thread onto the through hull fitting and then secured to backing plates with through bolts. The backing nut on the through hull fitting is not used. Mainesail has a great website providing detailed information on this here:
Compass Marine Project Articles Photo Gallery by Compass Marine at pbase.com
Dave S
help Restoring Small Old Fibreglass Boat mjonson Gear & Maintenance 19 05-03-2010 10:35 PM
St. Maartin, St. Barts & Anguilla bbayer4230 Chartering 2 04-23-2006 06:04 PM
Small Boat Cruising David Schaefer Cruising Articles 0 06-09-2004 08:00 PM
the perfect 20'' cruising boat? jbarros Boat Review and Purchase Forum 14 04-18-2004 06:45 PM
Closing Seacocks Tom Wood Gear and Maintenance Articles 0 12-20-2000 07:00 PM
