06-07-2010
Most modern transducers suggest 1 or two coats of bottom paint to prevent fouling. Even the biggest particles of copper in bottom paint are between 20 and 40 um (microns) in size. Your ultrasonic frequency is either 50 kHz or 200 kHz, or sometimes both (for depth sounders that work at depths >400 ft.)
Because these frequencies translate to wavelengths of 68.6 mm and 171.5 mm, respectively, and because both wavelengths are much larger than the copper particles (which are between 0.020mm and 0.040 mm), even the copper-laden bottom paint is perfectly transparent to your transducer.
This is the same reason that light can pass through glass (different frequency, though).
Anyhow, don't yell at the kid, he was doing the right thing, whether he knew it or not
Best Regards,
e
