Newbie rigging woes - Page 2 - SailNet Community
post #11 of 15 Old 06-10-2010 Thread Starter
YodaMouse's Avatar
Location: Ocala, Florida - a.k.a., Swampwater Boondocks
Yeah, I'm not going to sail with zip ties for sure. No, what I'm thinking is I saw another boat that had a tensioner affixed to the rear stainless steel handrail. I figure I can fabricate something like that as well, using stainless steel fittings and a pulley.
Also, I'm very cognizant of keeping an eye on the mast. So far, no pumping whatsoever.
Anyway, I will mull this over and maybe hold off until I have $$ to fix this. *Sigh* Gota be an adult. )
Vescere bracis meis.
(Eat my shorts.)
YodaMouse is offline
post #12 of 15 Old 06-10-2010
AdamLein's Avatar
Any idea why the backstay is so slack? Look at the boat from the side, preferable from a distance. How far aft is the mast leaning (raked)?
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
post #13 of 15 Old 06-10-2010 Thread Starter
YodaMouse's Avatar
I did that and the mast is pretty much at 90 degrees to the deck. Perhaps it is raked 1 or 2 degrees towards the bow, not the stern. (The chain plates for the shrouds are located slightly aft of the mast, centering it even without the backstay's tension.)
(Eat my shorts.)
post #14 of 15 Old 06-10-2010
Originally Posted by YodaMouse View Post
The turnbuckles on one side were maxed out while the other side had some slack. I evened them out.
Did you check the turnbuckles for the forestay and the backstay, to see if one of them is maxed out while the other has some slack? I had that happen on my last boat, and couldn't get the proper tension on the backstay, and equalizing them solved the problem.
Sailormon6 is online now
post #15 of 15 Old 06-10-2010 Thread Starter
YodaMouse's Avatar
No such luck. That was the case for the shrouds but not the back/forestay. And anyway, relieving the forestay tension would not fix this because the mast does not pivot on the sidestays-they attach to the deck slightly behind the mast.
(Eat my shorts.)
SSMR Inc. Rigging Services Review SVCarolena Gear & Maintenance 3 04-08-2011 12:26 PM
Rigging Woes svkarendipity Gear & Maintenance 7 03-13-2010 11:34 AM
Sailboat Rigging Danger eherlihy Gear & Maintenance 8 11-18-2009 04:40 PM
Standing Rigging Basics Mark Matthews Racing Articles 0 08-29-2004 09:00 PM
Replacing Your Standing Rigging Mark Matthews Gear and Maintenance Articles 0 12-15-2002 08:00 PM
