Old 06-08-2010
Red
redhead78 is on a distinguished road
Red face new stuffing box
Hey all, this past weekend I ran my new motor, after splash, I hand tightend packing nut, it was leaking pretty good, then ran engine at the slip very briefly, had a drip going and off. I tightened a little more drip stopped. I left the dock, motored for maybe, 1-3/4 hrs, had a good drip going, all seems well. The drip from the stuffing box was a blackish color. During the install of the shaft and cutlass brg ( all rubber) I was concerned it was a little to tight, I shot some WD -40 in the openings of the cutlass brg b-4 launch, probably should not have,I hope I am just seeing some break in residue?? At rest the packing looks to be holding. Weather did not permit any more motoring, so this weekend I plan to give it a much better test. Any ideas?? Red
Red, 77 Jeanneau Gin Fizz 38
Old 06-08-2010
deniseO30's Avatar
Lies about her age
make sure your bilge pump works??? wd 40 eats rubber and plastic hope you didn't shorten it's useful life. I've a pss dripless seal. stuffing box is supposed to drip they tell me. many use high tech packing.
Old 06-08-2010
Icarus05 is on a distinguished road
Go to this link:
Re-Packing A Traditional Stuffing Box Photo Gallery by Compass Marine at pbase.com
Either click or cut and paste in your address bar.
There are many other projects on this site. The gentleman who produces this website has the most explicit, accurate, exacting, and sound advice I've seen on the web on this subject. He also recommends the proper types of product to use. There are many other useful projects on the website too. I think once I found this I spent 8 hrs over two nights reading the whole site.
Hope it helps.
Old 06-09-2010
JimsCAL's Avatar
JimsCAL is on a distinguished road
Sounds like the stuffing box is adjusted correctly. No drips when stopped, a slow drip when running the engine, and not overheating the stuffing box. Just watch it and make additional adjustments as necessary.
Old 06-09-2010
SEMIJim's Avatar
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
When you say "ran engine at the slip," do you mean just running the engine, or were you turning the prop, as well?
Depending upon the answer to the above question: That may've been good, or may not.
Define "good drip going." For Gore GTU or GFO packing material that can be up to one drip every 20 seconds. For traditional material: One drip every ten.
Assuming you're not in "blackish coloured" water: That's bad. That indicates something is wearing/burning. (N.B.: Gore GTU or GFO may result in some gray-ish-ness initially. After all: It's carbon impregnated material. But the drip should soon turn clear.)
This is a separate issue. The stuffing box is inside your boat, above the shaft log. The cutlass bearing is outside your boat, well below the shaft log and in the water. How would wear from the cutlass bearing reveal itself in the drip from the packing gland?
No, you shouldn't have. Petroleum products are generally not recommended for rubber or plastic parts.
Any ideas??
See above. With the prop shaft turning you should get one drip every 20 seconds or less when using Gore GTU or GFO packing material, one drip every 10 seconds or less using traditional material. Also, the stuffing box should not get hot to the touch. Shouldn't get more than lukewarm, at the most. Any drip rates lowier than those, or a very warm or hot stuffing box will not only mean premature wear on the stuffing material, but you may score your prop shaft, after which you'll go thru stuffing material like, well, like water.
Btw: IME the Gore stuffing box material can take a lot of abuse w/o damaging it or your shaft. The first season I had it in, season before last, I was trying to get near the "optimal" one-drip-per-20-seconds adjustment. Couldn't get it. If I tightened just a hair past the per-10-seconds rate, the drip would stop entirely and the stuffing box a couple of times got down-right hot to the touch! So I settled for the 10-second rate. This spring we had the hose coupling the stuffing box to the shaft log replaced. The mechanics that did that job said the stuffing material and shaft were in fine shape.
Jim
s/v Abracadabra
1976 Pearson P30
Old 06-09-2010
Red
Re stuffing
First, when I said I ran at the dock, that was just because it was a brand new engine ANd I wanted to hear it run, I could not leave till high tide 7 hrs later. I tightened it as soon as it hit the water as it was just a couple of threads on. Then I tighened a bit till it stopped. Hours later as I motored to my yacht club, it was leaking like a drip every couple of seconds, and after I shut it down maybe 1-3/4 hours tyhere was no leak. As for the position of the cutlass brg, and the stern tube, I have a center cockpit, the stuffing box is attached to what I call the front of the stern tube, which is around 3' long, it runs under rear cabin,, then the rear of it the stern tube with the cutlass brg in it. The water enters the tube thru the slits in the cutlass brg fills the tube then drips out the stuffing box end correct?? So I think I have a mix of dirty water that should eventually clear out..I hope Red
Old 06-09-2010
jrd22's Avatar
Courtney the Dancer
New engine and cutlass bearing, did the shaft get aligned properly? If out of alignment it can be wearing the new cutlass bearing and that might be a source of the black you are seeing. If you are sure the shaft is perfectly aligned then I would guess it's coming from new packing. As long as it's dripping while in gear you should be OK.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 06-09-2010
Red
Since I just splashed it last week I think I will remove the coupler and look at the alignment again. This is a 1977 Jeanneau with a good 1 1/8" thick hull, so I don't think there was much flex......
Stuffing box blues capedory33 Gear & Maintenance 8 12-15-2004 10:20 AM
Work on the stuffing box while the boat is in the water pjfsail Gear & Maintenance 3 12-10-2003 05:25 AM
